TwinTurbo.NET: Nissan 300ZX forum - The cams are going to come out with the heads.
ZXoltan
on August 31, 2014 at 4:55 AM
Thanks guys. I have cyl 1 @ TDC and all marks seem aligned
posted by ZUL8R
on August 30, 2014 at 09:54 PM
You can check the head surface by using a straightedge and feeler gauges, but if you don't have the proper equipment (the straightedge must be exact) or the knowledge then do yourself a favor and take it to a machinist to be checked.
How to replace head gasket with engine out. Keeping timing?
ZUL8R
20:11:13 08/29/14
Obviously this is your first time around..
Cjw3
12:29:27 08/30/14
If you are talking about ignition timing
-Grimm-
12:33:52 08/30/14
Set your #1 piston to TDC and your crank pulley to align
SammybTT(TN)
12:33:32 08/30/14
ZUL8R
21:54:45 08/30/14
The cams are going to come out with the heads. -
ZXoltan
04:55:13 08/31/14
Thanks gents. Any thoughts on this deck and gasket?
ZUL8R
23:57:17 09/01/14
sorry - 5 is bottom of pic, not top. (n/m)
ZUL8R
23:59:15 09/01/14
Doesnt look too horrible
-Grimm-
17:18:54 09/02/14
Thanks sir. Can I use OEM HG if heads get shaved?
ZUL8R
21:49:24 09/02/14
Factory states 0.008" is the deck limit
-Grimm-
09:41:43 09/03/14
Thanks Grimm. Don't the Cometics have a high failure rate? (n/m)
ZUL8R
12:12:46 09/03/14
ZUL8R
13:08:23 09/03/14
